Ubuntu Connection with Plex
Must remember –
multimedia -OR- Multimedia ???
Thought it was /home/multimedia on Linux ??
Hi, i have a new Server, but i cant connect with the other server:
dexx@30:~$ rclone mount ftp:files/ /home/dexx/multimedia/ -vv --allow-other
2024/01/22 18:33:23 DEBUG : rclone: Version “v1.64.2” starting with parameters [“rclone” “mount” “ftp:files/” “/home/dexx/multimedia/” “-vv” “–allow-other”]
2024/01/22 18:33:23 DEBUG : Creating backend with remote “ftp:files/”
2024/01/22 18:33:23 DEBUG : Using config file from “/home/dexx/.config/rclone/rclone.conf”
2024/01/22 18:33:23 DEBUG : ftp://IP:21/files: Connecting to FTP server
2024/01/22 18:33:23 DEBUG : ftp://IP:21/files: dial(“tcp”,“45.87.251.134:21”)
2024/01/22 18:33:23 DEBUG : ftp://IP:21/files: > dial: conn=*fshttp.timeoutConn, err=
2024/01/22 18:33:23 INFO : ftp://IP:21/files: poll-interval is not supported by this remote
2024/01/22 18:33:23 DEBUG : ftp://IP:21/files: Mounting on “/home/dexx/multimedia/”
2024/01/22 18:33:23 Fatal error: failed to mount FUSE fs: fusermount: exec: “fusermount3”: executable file not found in $PATH
@marco_6118
  1. Putting the files in your home directory brings a separate set of problems. Using something like /home/multimedia, which your username also owns, is better because you are in full control of it.
  2. Did you sudo apt install fuse ? Judging by your errors above, you don’t have fuse installed correctly
Be advised, I see this floating out on the internet. I’ve not had time to research it.
Warning: Do not install the fuse package as of 22.04 or > you may break your system
sudo add-apt-repository universe
sudo apt install libfuse2
i try it, how can i reset the plex
2024/02/05 19:29:21 DEBUG : ftp://IP:21/files: closing 1 unused connections
DEBUG : : forgetting directory cache
i have unmount every mount option, but i become everytime this message
And I have still the video quali on 1080p ,but ist lagging every 10-20 sek
May I see the playback DEBUG server logs ZIP file?
