Yes, perform your rclone mount now and let PMS try to use it.
Let’s see what happens.
withe the root user, or dexx User?
should I then create a /home/dexx/Multimedia folder again`?
mount it at /home/multimedia like we set up.
Mount it as the root user.
Permissions of /home/multimedia should be 755 before the mount
Permissions of /home/multimedia should be 755 after the mount
root@vmd122137:~# rclone mount ftp:files /home/multimedia/ -vv --allow-other
2023/11/19 17:16:04 DEBUG : rclone: Version “v1.53.3-DEV” starting with parameters [“rclone” “mount” “ftp:files” “/home/multimedia/” “-vv” “–allow-other”]
2023/11/19 17:16:04 DEBUG : Creating backend with remote “ftp:files”
2023/11/19 17:16:04 DEBUG : Using config file from “/root/.config/rclone/rclone.conf”
2023/11/19 17:16:04 DEBUG : ftp://IP:21/files: Connecting to FTP server
2023/11/19 17:16:05 INFO : ftp://IP:21/files: poll-interval is not supported by this remote
2023/11/19 17:16:05 DEBUG : ftp://IP:21/files: Mounting on “/home/multimedia/”
2023/11/19 17:16:05 DEBUG : : Root:
2023/11/19 17:16:05 DEBUG : : >Root: node=/, err=
Ok is Mounting
Something is wrong with /home and ‘/’ permissions.
This is from my Ubuntu Server installation.
You can see /home.
Permissions for / are 755
Permissions for /home are 755
Here it is clear, Plex can see /home.
mhh how can i change it?
i have make now :
sudo chmod 755 /home/multimedia
sudo chmod 755 /
I have another Linux server from a different provider
Try the other provider – OR – try Ubuntu.
it is Ubuntu
SSH tunnel to it , use :
It is remote. Standard claiming rules apply again…
I have the rclone Job in Backround it is enough?
I have activated the daily search in pms
If you want rclone to startup every time the system starts (which is logical),
Add the command to launch rclone in /etc/rc.local ( executable script file you create )
This way, every startup will execute the rclone mount command however you want it.
An alternative way is to create a systemd service in /etc/systemd/system
I would call it /etc/systemd/system/marco-rclone.service
You then create a basic service file with ExecStart and ExecStop definitions so you can mount & unmount as you need.
uuii complicated
Is it normal for some movies to lag at 2160p?
the buffer is very low
Depending on network/connection speeds between server and player AND bitrate of video being played, yes it is possible.
You’re using FTP to pull the media file contents. FTP isn’t quick. HTTPS would be much faster on the same connection.
The buffer in the player is device-dependent. Each device limits how much memory the player can have/use
How can I switch to Https?
Plex say, the file are not ready
