Ubuntu - migrate standard installation of Plex to Docker
Hello,
using Plex server in my Ubuntu Server 18.04. Everything works great.
I just read Plex in Docker is better solution (don’t know why).
So I want to move Plex to Docker, then remove standard installation so it will be in Docker only.
And of course want to migrate stats, seen multimedia etc.
How can I do that please?
Plex in Docker isn’t a “better” solution. There are multiple, equally valid, solutions.
You should go with what you are best with; Windows, Linux, Docker, etc.
Here is the support page for moving to another system (which docker qualifies as).
Pesonally, I don’t understand the reasons for Docker:
  1. It’s abstracted from the host it’s running on
  2. It’s far less portable
  3. UID/GID/Network/media mapping can get all balled up
  4. Hardware transcoding isn’t native.
  5. It is NOT as portable as touted.
Again, personally, I think people are using Docker because they can / it looks cool.
It’s intended to be used when no native package exists.
In this case, it’s already native.
what’s the net gain?
