Server was running fine for years, suddenly its refusing to serve anything.
Ubuntu 16.04.5 LTS
PMS: 1.14.1.54880cc260c476
PMS service is running, however when i try to connect from http://:32400/web it gives an ERR_CONNECTION_CLOSED in Chrome. (ofcourse, router portforward is checked)
When i try to connect on local lan http://:32400/web, it does start the webinterface, and allows me to login. However, the media server shows as offline.
Tried to update the server (it was running 1.13.xxx when the problem occurred), no difference, still same problem.
Followed the DB repair procedures, still same problem.
Deleted all ssh/cert/key files, reinstall 1.14.xxx, still same problem.
Tried to delete database, still same issue.
(reverted back all of above, back to my baseline)
As i cannot enter the server settings, i’m not able to enable debug logging. In the regular log, i dont see any issues, yet, the server is not reachable…
Plex media server log: https://pastebin.com/jcUjTpeT
Results of systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/etc/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2019-01-07 20:43:27 CET; 31min ago
Process: 8865 ExecStartPre=/bin/sh -c /usr/bin/test -d “{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 8869 (sh)
CGroup: /system.slice/plexmediaserver.service
├─8869 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server
├─8870 /usr/lib/plexmediaserver/Plex Media Server
├─8883 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-cc260c476/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.14.1.5488-cc260c476 /usr/lib/plexmediaserver/
├─8932 /usr/lib/plexmediaserver/Plex DLNA Server
└─8933 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.14.1.5488-cc260c476 32600 /waitmutex
Jan 07 20:43:27 stream.acasis.nl systemd[1]: Starting Plex Media Server for Linux…
Jan 07 20:43:27 stream.acasis.nl systemd[1]: Started Plex Media Server for Linux.
Anyone can point me to a direction how to troubleshoot and solve this issue ?
