Can't connect to plex all of a sudden
Server Version#: Don’t know can’t access webpage probably latest though, I keep it updated.
Player Version#: Same
It’s on Ubuntu server 20.04. There’s nothing in the logs that’s helpful. The server has worked for months now but, all of a sudden, when I attempt to connect directly on port 32400, it says the connection is unexpectedly closed.
I have no idea what to do.
In Firefox, the error is more detailed:
An error occurred during a connection to 192.168.75.202:32400. PR_END_OF_FILE_ERROR
I have the same issue but with windows server, in that thread is a user with the same issue on Ubuntu
https://forums.plex.tv/t/plex-media-server-will-not-start-since-latest-upgrade-tried-everything/650506/8
Yep, here too…
https://forums.plex.tv/t/latest-version-1-20-4-3517-crashes-with-errors-on-libcrypto-and-ssl/650694/2
Anyone know how to rollback a Plex install?
I tried navigating to https://downloads.plex.tv/plex-media-server-new/ to look for old versions but apparently it just redirects you to the latest version? How are old versions not easily available??
OK, I’ve spun up a completely new VM of ubuntu 20.04.
I’ve installed the older version of PMS: plexmediaserver_1.20.3.3483-211702a9f_amd64.deb
The same behavior is occuring.
Here is /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log:
Something is very wrong…
I’ve now added the Plex repository and upgraded to plexmediaserver_1.20.4.3517-ab5e1197c_amd64.deb
sudo lsof -i -P -n | grep LISTEN shows:
However, navigating to 192.168.75.202:32400/web/index.html looks the same as when I didn’t have PMS installed. As far as my browser is concerned nothing is listening on port 32400…
nmap -APn 192.168.75.202 -p 32400 shows the following output:
May I please request:
  1. When posting console output, use the inline method.
``` (grave - back tick character)
[chuck@lizum ~.503] sudo lsof -i -P -n | grep 324 Plex\x20M 109817 plex 60u IPv4 3042295 0t0 TCP 192.168.0.13:39322->78.132.50.219:32400 (ESTABLISHED) Plex\x20M 109817 plex 67u IPv4 1347092 0t0 TCP *:32400 (LISTEN) Plex\x20M 109817 plex 68u IPv4 1347094 0t0 TCP 127.0.0.1:32401 (LISTEN) Plex\x20M 109817 plex 78u IPv4 1369394 0t0 TCP 192.168.0.13:44176->192.168.0.21:32400 (ESTABLISHED) Plex\x20M 109817 plex 99u IPv4 1347498 0t0 UDP *:32414 Plex\x20M 109817 plex 102u IPv4 1347499 0t0 UDP *:32410 Plex\x20M 109817 plex 110u IPv4 1347500 0t0 UDP *:32412 Plex\x20M 109817 plex 111u IPv4 1347501 0t0 UDP *:32413 [chuck@lizum ~.504]
produces the very nicely readable
[chuck@lizum ~.503]$ sudo lsof -i -P -n | grep 324
[chuck@lizum ~.504]$
  1. May I please have the Server log files ZIP (DEBUG ON, VERBOSE OFF) ?
    The ports info only shows if there is a problem.
    The server logs , captured 2 minutes after startup, will tell us where it is
