Server Version#: 1.14.1.5488
Player Version#:3.77.4
Server OS Version#: Ubuntu Server 18.04.2 x86_64
Tuner: WinTV quadHD 165100 LF Rev B416
I have followed the instructions outlined here: http://www.hauppauge.com/pages/support/support_linux.html#plex
I have done this on both Ubuntu 16.04 and 18.04. I have Plex Pass. Once everything is installed, I go to set up the DVR and no device is listed.
The Plex Tuner Service.log is listed at the bottom. I don’t know what else to do. I started out trying this in a virtual environment and passing the device through to the VM, but that was unsuccessful and I figured that it being a VM was the reason for the failure. I then installed a fresh copy of Ubuntu on a standard PC installed all updates, installed PMS, followed the instructions listed on the web page above including adding the plex user to the video group.
I have also download the firmware file from linuxtv.org and placed it in the lib/firmware folder.
Nothing seems to work. I don’t know what I’m missing.
Linux lists the device when I execute lspci -v. The results of that are listed below the log. I do see that one of the items does not show a Kernel driver in use. I’m at a loss as to what else I need to do to get this working.
I tried it in Windows just to confirm if the tuner was functional and Plex does see the tuner when installed in Windows.
If someone can help, I’d greatly appreciate it.
Mar 01, 2019 00:25:44.222 [0x7f30268de700] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build:
Mar 01, 2019 00:25:44.222 [0x7f30268de700] INFO - Linux version: 4.15.0-45201902141402-generic (#0+mediatree+hauppauge-Ubuntu SMP Thu Feb 14 21:20:16 UTC 2019), language: en-US
Mar 01, 2019 00:25:44.222 [0x7f30268de700] INFO - Processor Intel® Core™ i5-3470 CPU @ 3.20GHz
Mar 01, 2019 00:25:44.223 [0x7f30268de700] INFO - /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.14.1.5488-cc260c476 32600 /waitmutex
Mar 01, 2019 00:25:43.807 [0x7f302b9db7c0] INFO - [I] broker_t::start…
Mar 01, 2019 00:25:44.582 [0x7f302b9db7c0] INFO - [I] device_manager_t::init.
Mar 01, 2019 00:25:44.582 [0x7f302b9db7c0] INFO - [I] device_manager_t::init. Initialize provider manager
Mar 01, 2019 00:25:44.582 [0x7f302b9db7c0] INFO - [I] device_manager_t::init. Initialize all device auxes
Mar 01, 2019 00:25:44.582 [0x7f302b9db7c0] INFO - [I] dvb_device_factory_t::get_aux_list
Mar 01, 2019 00:25:44.583 [0x7f302b9db7c0] INFO - [I] tvbutler_aux_t::init
Mar 01, 2019 00:25:44.754 [0x7f302b9db7c0] INFO - [I] web_server_t::start. Starting web server on port 32600
Mar 01, 2019 00:25:47.985 [0x7f30248da700] INFO - [I] web_service_t::process_device_discovery
Mar 01, 2019 00:25:47.986 [0x7f30248da700] INFO - [I] device_reactor_t::get_device_list ()
Mar 01, 2019 00:25:47.986 [0x7f30248da700] INFO - [I] dvb_device_factory_t::get_device_list ()
Mar 01, 2019 00:25:49.989 [0x7f30248da700] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Mar 01, 2019 00:25:50.393 [0x7f30248da700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Mar 01, 2019 00:25:50.396 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx >>
Mar 01, 2019 00:25:50.398 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 5050:23
Mar 01, 2019 00:25:50.398 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
Mar 01, 2019 00:25:50.398 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 32903:36
Mar 01, 2019 00:25:50.398 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1133:49174
Mar 01, 2019 00:25:50.398 [0x7f30248da700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Mar 01, 2019 00:29:55.153 [0x7f301e7fc700] INFO - [I] web_service_t::process_device_discovery
Mar 01, 2019 00:29:55.153 [0x7f301e7fc700] INFO - [I] device_reactor_t::get_device_list ()
Mar 01, 2019 00:29:55.153 [0x7f301e7fc700] INFO - [I] dvb_device_factory_t::get_device_list ()
Mar 01, 2019 00:29:57.157 [0x7f301e7fc700] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Mar 01, 2019 00:29:57.560 [0x7f301e7fc700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Mar 01, 2019 00:29:57.563 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx >>
Mar 01, 2019 00:29:57.564 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 5050:23
Mar 01, 2019 00:29:57.564 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
Mar 01, 2019 00:29:57.564 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 32903:36
Mar 01, 2019 00:29:57.564 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1133:49174
Mar 01, 2019 00:29:57.564 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Mar 01, 2019 00:29:57.565 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 32903:36
Mar 01, 2019 00:29:57.565 [0x7f301e7fc700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Mar 01, 2019 00:29:59.644 [0x7f301effd700] INFO - [I] web_service_t::process_device_discovery
Mar 01, 2019 00:29:59.645 [0x7f301effd700] INFO - [I] device_reactor_t::get_device_list ()
Mar 01, 2019 00:29:59.645 [0x7f301effd700] INFO - [I] dvb_device_factory_t::get_device_list ()
Mar 01, 2019 00:30:01.648 [0x7f301effd700] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Mar 01, 2019 00:30:02.052 [0x7f301effd700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Mar 01, 2019 00:30:02.055 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx >>
Mar 01, 2019 00:30:02.055 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 5050:23
Mar 01, 2019 00:30:02.055 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
Mar 01, 2019 00:30:02.056 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 32903:36
Mar 01, 2019 00:30:02.056 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1133:49174
Mar 01, 2019 00:30:02.056 [0x7f301effd700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
03:00.0 Multimedia video controller: Conexant Systems, Inc. CX23887/8 PCIe Broad cast Audio and Video Decoder with 3D Comb (rev 04)
Subsystem: Hauppauge computer works Inc. WinTV-quadHD
Flags: fast devsel, IRQ 17
Memory at f7a00000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [90] Vital Product Data
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [100] Advanced Error Reporting
Capabilities: [200] Virtual Channel
Kernel driver in use: cx23885
Kernel modules: cx23885
04:00.0 Multimedia video controller: Conexant Systems, Inc. CX23887/8 PCIe Broad cast Audio and Video Decoder with 3D Comb (rev 04)
Subsystem: Hauppauge computer works Inc. CX23887/8 PCIe Broadcast Audio and Video Decoder with 3D Comb
Flags: fast devsel, IRQ 11
Memory at f7800000 (64-bit, non-prefetchable) [disabled] [size=2M]
