When are you going to support Ugreen nas drives with an easy to install/ run app as you do with say Synology?
These Ugreen nas are high performance and growing in popularity
Maybe you should edit the plex-web to something more appropriate so it gets the attention it deserves. (I use Windows, so I’m no help)
TruNas is supported by Plex and your NAS can run it…
If you can run Docker on the NAS then you can use PMS in Docker on it now.
As for a native package (like Synology, QNAP, or the others), Ugreen would need to contact Plex Inc management and make the appropriate development arrangements.
Ugreen runs debian Linux so you can install plex natively using the debian installation.
