UI issues
Server Version#: 1.40.4.8598
Player Version#: Xbox v2.141.0 (client v5.85.0)
From few time there are issues with displaying Movie and TVShow backgrounds.
If is chosen Cover colors as type of background the tv art for TVShows is missing when you go in episode view.
So this is in seasons view:
This is in episodes view (missing art where it should be):
For all elements in home screen when you first open the plex app it show a blurred art and that is not fixable till you open and close the right hand menu. (That is very old bug that no one bothers to fix!!!)
This is how it looks once you open the app (Broken since the art is blurred):
This is how it looks after you visit right hand menu:
The above bugs are not present in Android version of the app…
I hope that will be fixed as soon as possible since that is very annoying… :frowning: :frowning: :frowning:
Also i hope there can be possibility to write the language of the Audio track and not only the codec…
P.S. If you lack a developers to do that i can offer my service as a developer for windows. This is what i work and i believe i can help with that. Besides that are minor bugs that should not be hard to fix…
Hopefully some plex staff will see this and address it. There is no point of fixes otherwise fot functionality that is rarely used and not even seen…
This issues are crearly visible and annyoing for end user…
So please address them
