I think they’re getting in touch with their metadata provider.
Don’t know how to put this nicely, I am using Youview(Central -South) as a last resort, I select the channels I want and make sure they are mapped ok but the epg does not show all the upcoming programs, eg I only select channel 4HD and wait for the epg to update, I get 370 airings, the epg shows 20
Starting Soon 1
On Now 1
New Episodes Tonight 5
My Upcoming Shows 1
Recommended for You 5
Upcoming Movies 7
No Sport, it does not show the upcoming Canadian GP or any sport and only a max of 7 programs in the other categories.
This is not an epg that I can use.
I am using a HDHomerun Connect and Plex Unraid Docker 1.5.6. 3790
Either I totally misunderstand the concept of an epg or Plex still have a lot of work to do, or I have missed something.
I want Freeview with an epg that shows either 7 or 14 days for each channel, forget the other stuff.
dd you try searching or discover by Episodes / Channel, sometime the guide data is not always accurate?
Thank you, I will have a play with it and see how I can work with it, grid listing like Digiguide would be my choice if possible.
What method do you use to try and pick the programs you might want to record?
search, far quicker ![]()
