I’m OX25 / Freeview Meridian/Central OTA, but stopped using Plex because it wasn’t good enough anymore. I just checked out mine again and it looks the same:
HI There,
Having same problem with Danish Cable provider. No Guide data available.
Dropped the DVR to re-install. During re-install no danish zip codes can be found
UPDATE. For some reason, if I access the a Guide on my iPhone or iPad, all programmes are there and look normal. None of the e.g. “BBC1 Programming” messages i am seeing on the web app.
I’ll post this on the other thread discussing the same subject in case it’s of use to anyone.
This issue is being worked on. Plex for iOS and Plex for tvOS appear to be resilient but other client apps are affected. It is due to duplicate old generic schedule data which overlap the new data.
