Unable to access to ip:32400/web for the initial setup
Server Version#: PlexMediaServer-1.25.4.5487-648a8f9f9
Hello I installed plexmediaserver under rasperryOS 64bits but i got an unexpected error when I try to access for the first time to localhost:32400/web
Any idea?
Thaks in advance
What was the error?
Any PMS logs ?
This is the error, in spanish
I did not find any error in the log.
log PMS.txt (196.1 KB)
Absolutely nothing shows in the single log file you uploaded
Was there no more log files?
And if so, all of them in a zip please
Two plus files
Plex Crash Uploader.log (183 Bytes)
Plex Tuner Service.log (1.9 KB)
I understand the “plugins folder logs” is not needed. All those files are in /var/lib/plexmediaserver/Library/Application Support/PlexMediaServer/Logs
And this is how the log grows when I reload “ip:32400/web”
PMS.log (59.9 KB)
If I use this url: “ip:32400/web/index.html” the login window is showed but when I write user & pass the same error page appears again.
Very strange, and nothing in the logs indicating anything
What was the exact filename of the PMS you downloaded and installed?
I added the repositories and I did “sudo apt install plexmediaserver” and it was fine.
At the end I did not register the new plex server into my plex user and I could configure the server and add the media libraries. When it finished then I could add the server to my plex account… Strange behaviour but it worked and now is working.
plexmediaserver versiĂłn 1.25.4.5487-648a8f9f9 platform arm64
Thanks for your time
