Unable to browse library after filtering/sorting
sorry it was the link to internal issue.
Honestly, I’m scared to. The original filtering bug made the app completely unusable. Sort by unwatched isn’t something I normally do so I’ll avoid this bug for now.
While consolidating the client into a single codebase is the correct approach, Plex released this to production before extensive beta testing and now they risk tarnishing the brand.
And while I’m grousing, I’m a long time happy Plex user since 2008. I have one of the old lifetime Plex Passes. Plex has been quality for almost two decades, I always recommend it to my friends. But using forums as the only way to track bugs publicly is bad full stop. Expose a real issue tracking system so you can consolidate multiple reports. You wouldn’t do that internally, it’s also a bad customer experience externally.
When I had the problem awhile back, the whole Plex App froze on me. I couldn’t do anything at all with the app so I uninstalled and reinstalled it and didn’t mess with it until an update came that said it fixed the sorting issue and it did. Maybe that could kick the issue out for you.
I did uninstall and test again.
Issue is still present.
Thats why it is still an open issue for the dev.
Issue still present in version
2025.16.0
Do you have an ETA for this issue ?
Was hoping to be part of today version but its not
Sorry I don’t have ETA but the report shows as In Progress so they are actively working on it.
2025.17.0
Is the Ticket still in progress?
Yup. Just checked on status and it is being actively worked on right now.
Still not fixed
Version 2025.18.0
Are they really working on it ?
It doesnt seem a complicatee issue to fix , if it was working on og app and its working on web and xbox app for example
Finally fixed in last version
Thank you
Issue returned? I filtered library and now I just get a no results screen with no filter dropdowns so I can’t change the filter that’s resulting in no results and it’s bricked
