When I go to filter by unwatched and then sort by unwatched it freezes and never loads the library. On constant buffering.
Are you using the new app? We need more details on what platform and version you’re experiencing this on.
Also, if you filter to show only unwatched, then why do you have to sort by unwatched? Isn’t everything in that filtered list all unwatched?
This is a known Issue, what version of plex are you using.
Avatar/ settings/ about
It’s only on the new app. The PC version is still ok.
The reason I sort is I can see which shows I have the most episodes left to watch in that order.
It’s not a needs thing. Just wanted to point out since the new change it’s not functioning.
PV 14
CL 2025.15.0
You responded fast haha. I just updated post. That’s the version I have
If that has not fixed the issue we have to wait for 16 at least. I know it was reported.
