If you can’t sign in, I don’t know what logs you would have. You could maybe check the browser developer console and see if there are any errors.
It’s with my browsers that I have. I would have to check each browser?
I ran the developer console and got these errors
Failed to execute ‘postMessage’ on ‘DOMWindow’: The target origin provided (‘https://app.plex.tv’) does not match the recipient window’s origin (‘https://www.plex.tv’).
B @ iframeResizer.min.js:8
d @ iframeResizer.min.js:8
i @ iframeResizer.min.js:8
(anonymous) @ iframeResizer.min.js:8
o @ plex.fedauth.min.js:1
(anonymous) @ plex.fedauth.min.js:1
i @ jquery.min.js:2
add @ jquery.min.js:2
n.fn.ready @ jquery.min.js:2
authAppiFrame @ plex.fedauth.min.js:1
start @ plex.fedauth.min.js:1
d @ plex.fedauth.min.js:1
dispatch @ jquery.min.js:3
r.handle @ jquery.min.js:3
trigger @ jquery.min.js:4
(anonymous) @ www.plex.tv/:1916
(anonymous) @ jquery.min.js:4
each @ jquery.min.js:2
s @ lib.min.js:10
(anonymous) @ lib.min.js:10
a @ lib.min.js:10
chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81 [Auth] Metrics context {
“device”: {
“product”: “Plex SSO”
chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81 Did not move header “accept” to query string. This can result in an unnecessary OPTIONS preflight request.
onLogMessage @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
onLog @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
x @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:52
trigger @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:52
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:52
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
F/us.m.each.m.forEach @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
hp @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
each @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:36
a @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
dt @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
ajax @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
Md @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
Dd @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
l @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
add @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
Deferred @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
then @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
Yd @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
REM4 @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
a @ app.plex.tv/:26
t @ app.plex.tv/:26
r @ app.plex.tv/:26
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:1
(unknown) POST https://plex.tv/api/v2/users/signin?X-Plex-Product=Plex%20SSO&X-Plex-Client-Identifier=9a873118-9d2b-05fe-e4be-1fef7c20eb54 net::ERR_CONNECTION_TIMED_OUT
(anonymous)
i @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
send @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:47
a @ app.plex.tv/:26
t @ app.plex.tv/:26
r @ app.plex.tv/:26
dn @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:52
Kn @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:52
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:102
onSignInSubmit @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
onSubmit @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
u @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
h @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
(anonymous) @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
C @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
O @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
P @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
j @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
Tn @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
Es @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
Fe @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
On @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
t.unstable_runWithPriority @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:10
As @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
An @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:130
r @ chunk-0-0af89d120e9eb235ad6c-plex-4.46.3-f207ffd.js:81
Show 6 more frames
(unknown) POST https://plex.tv/api/v2/users/signin net::ERR_CONNECTION_TIMED_OUT
(anonymous)
send @ jquery.min.js:4
ajax @ jquery.min.js:4
getUserAPIPromise @ plex.fedauth.min.js:1
loadSSO @ plex.fedauth.min.js:1
signInSSO @ plex.fedauth.min.js:1
(anonymous) @ app.min.js:2
i @ jquery.min.js:2
fireWith @ jquery.min.js:2
J @ jquery.min.js:2
(anonymous)
DevTools: CPU profile parser is fixing 87 missing samples.
DevTools: CPU profile parser is fixing 411 missing samples.
DevTools: CPU profile parser is fixing 4 missing samples.
DevTools: CPU profile parser is fixing 1 missing samples.
2DevTools: CPU profile parser is fixing 2 missing samples.
DevTools failed to load SourceMap: Could not load content for https://www.plex.tv/wp-content/themes/plex/assets/js/conditional/lib/iframeResizer.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
That would indicate something is interfering with the connection back to plex.tv. Do you have any type of ad-blocker, firewall, or other internet security feature running?
The only other thing I can think is to check your browser and make sure it is allowed to run javascript.
I turned off some settings to windows defender and these codes popped up
Show 6 more frames
VM2143:1 POST https://plex.tv/api/v2/users/signin?X-Plex-Product=Plex%20SSO&X-Plex-Client-Identifier=9a873118-9d2b-05fe-e4be-1fef7c20eb54 net::ERR_CONNECTION_CLOSED
Doesn’t look like that was the culprit. Anything else going on with your computer?
I turned off firewall, any ad blockers and any internet security (even though I never had to change those settings when I installed Plex)
The only thing that was different was I connected my work laptop to my router via Ethernet cable. I already restarted my router and nothing has changed
Do not do that.
So what did you have installed? Some of these type of programs don’t actually turn off and can cause issues just being installed.
It was just the ad shields on Brave Browser and I had Malwarebytes installs but I uninstalled it
Did you restart your computer after this? I’ve seen their app leave stuff running even after an uninstall.
Yes I did restart after uninstalling Malwarebytes.
I’m out of ideas, sorry.
Should I reset windows?
You can try, but not knowing what the cause is, I can’t say if that will fix the problem.
