I have been using Plex for a few years, but recently started having issues with this. About 1 month ago I moved Plex Media Server from a Windows 7 Computer to a Windows 10 computer. Ever since I haven’t been able to get a direct connection. I can connect indirectly through remote access
I have a modem from my ISP that is in Bridged mode. I have an Asus Router. I have a static IP from the ISP. I have assigned an IP Address to the computer Plex media servier is on through the router. I have enabled port forwarding in the router on port 32400. I have port forwarding working for numerous other things without issue. I had port forwarding working with Plex Media Server when it was on my Windows 7 computer. I can connect remotely if I turn off the manual option, but then I don’t have a direct connection. I have checked Windows Firewall and there are exceptions for local and internet set for 3 or 4 different Plex programs.
I’m really baffled on what I’m missing here. Why isn’t this working? What am I missing by not having a direct connection? Will streaming over the WWW still work without a direct connection? Any ideas what I should do to fix this
