Unable to pause, fast forward or rewind movie during play
When playing a movie I am unable to pause, fast forward or rewind the movie. Only option I have is go back to stop the movie.
It all works fine on my ATV 2 version 5.3 with the same configuration as below.
Is there any sollution? I am glad to provide more info if needed.
  • ATV 3 6.0.1
  • DNS Server: 192.168.0.198
  • Synology DS 412+ DSM 4.3-3776-3
  • The local IP address of the device that PlexConnect is installed on: 192.168.0.198
  • PMS installed on Synology DS 412+  version 0.9.8.10.215-020456b
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.198
  • The PlexConnect version number: Latest Commet 411
  • The content of your 'Settings.cfg' file: [PlexConnect]
    logpath = ../../var
    enable_dnsserver = True
    ip_webserver = 0.0.0.0
    prevent_atv_update = True
    enable_plexconnect_autodetect = True
    port_pms = 32400
    port_webserver = 81
    ip_plexconnect = 0.0.0.0
    certfile = ../../etc/certificates/trailers.pem
    ip_dnsmaster = 8.8.8.8
    loglevel = Normal
    ip_pms = 0.0.0.0
    enable_plexgdm = True
    port_ssl = 443
    enable_webserver_ssl = True
    port_dnsserver = 53
  • Attached the PlexConnect.log with loglevel to High
This is, I think, a known bug. At least it happens to me often.
Workaround:
Stop what you're watching, go back to the plexconnect menu, select the movie again, and resume play.
9 times out of 10 that fixes it. If not, try the steps again. I've never had to restart the movie more than twice.
(if the play progress bar is fully white, pause, etc., won't work. replay until you have a blue bar.)
