Sorry about posting without the requested info. Here you go. I am going to try and figure out how to set plexconnect to transcode and see if that helps.
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
6.0.2
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
172.16.16.5
The device and operating system (including version number) that PlexConnect is installed on:
Custom Server > VMware 5.5 > Ubuntu server 12.04
The local IP address of the device that PlexConnect is installed on:
172.16.16.5
The device and operating system (including version number) that the Plex media server (PMS) is installed on:
The Plex media server (PMS) version number you are running (do not put 'latest'):
0.9.8.4
The local IP address of the device that the Plex media server (PMS) is installed on:
172.16.16.5
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
Github download around Nov 24
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 172.16.16.5
enable_plexgdm = False
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to
http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
Can't figure out the xml past to the website so it's a 1080p DTS5.1 file
