This only started recently, but when I attempt to play back some media (not all) I get the following output in my logs and the media is unable to play. This is on web player, Android app, roku, etc. Seems server side so same outcome regardless of the player.
Server Version#: 1.18.5.2309
Player Version#: Any device
==> ./Plex Media Server.log <==
coder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:33.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8qo0jnbn4g6l9d4n0xlfba5q_606-0-25.wavâ
Feb 03, 2020 08:05:33.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] error reading output
Feb 03, 2020 08:05:33.001 [0x7f07967fc700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:36.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8qo0jnbn4g6l9d4n0xlfba5q_606-0-26.wavâ
Feb 03, 2020 08:05:36.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] error reading output
Feb 03, 2020 08:05:36.002 [0x7f07967fc700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:39.000 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8qo0jnbn4g6l9d4n0xlfba5q_606-0-27.wavâ
Feb 03, 2020 08:05:39.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] error reading output
Feb 03, 2020 08:05:39.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:42.000 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8qo0jnbn4g6l9d4n0xlfba5q_606-0-28.wavâ
Feb 03, 2020 08:05:42.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] error reading output
Feb 03, 2020 08:05:42.001 [0x7f07967fc700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:45.000 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/8qo0jnbn4g6l9d4n0xlfba5q_606-0-29.wavâ
Feb 03, 2020 08:05:45.001 [0x7f07967fc700] ERROR - [Transcoder] [eac3_eae @ 0x1319180] error reading output
Feb 03, 2020 08:05:45.002 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:05:45.689 [0x7f0795ffb700] WARN - Transcode runner appears to have died.
Feb 03, 2020 08:05:45.699 [0x7f07777fe700] WARN - Transcode runner appears to have died.
Feb 03, 2020 08:06:19.125 [0x7f0775ffb700] INFO - AutoUpdate: no updates available
Feb 03, 2020 08:06:37.784 [0x7f07777fe700] INFO - AutoUpdate: no updates available
Feb 03, 2020 08:06:46.000 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-0.wavâ
Feb 03, 2020 08:06:46.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:06:46.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:06:49.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-1.wavâ
Feb 03, 2020 08:06:49.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:06:49.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:06:52.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-2.wavâ
Feb 03, 2020 08:06:52.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:06:52.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:06:55.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-3.wavâ
Feb 03, 2020 08:06:55.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:06:55.002 [0x7f0795ffb700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:06:58.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-4.wavâ
Feb 03, 2020 08:06:58.001 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:06:58.002 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:07:01.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-5.wavâ
Feb 03, 2020 08:07:01.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:07:01.002 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:07:04.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-6.wavâ
Feb 03, 2020 08:07:04.001 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:07:04.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:07:07.000 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-7.wavâ
Feb 03, 2020 08:07:07.001 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:07:07.002 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:07:10.000 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-8.wavâ
Feb 03, 2020 08:07:10.001 [0x7f076ffff700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:07:10.001 [0x7f076ffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Feb 03, 2020 08:07:13.000 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] EAE timeout! EAE not running, or wrong folder? Could not read â/tmp/pms-48afc2af-230b-473c-aea2-723e642d8fd7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/cyovi36egwi3b0x7kpc42ncl_675-0-9.wavâ
Feb 03, 2020 08:07:13.001 [0x7f0795ffb700] ERROR - [Transcoder] [eac3_eae @ 0xddc180] error reading output
Feb 03, 2020 08:07:13.001 [0x7f0795ffb700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
