Unable to play videos with DTS audio
Server Version#: 1.14.1.5488
Player Version#: 3.77.4
OS: CentOS 7.6
Plex Media Server Logs_2019-02-24_00-56-54.zip (1.7 MB)
When trying to play any video with DTS audio I get an error “Conversion failed. A required codec could not be found or failed to install.”
I see errors in the logs about “Codecs: Failed to download XML for codec h264_decoder” that may or may not be related. I can play other h264 videos that have other audio Codecs.
I cannot play with the web client in any browser, in the Android app or to a Chromecast.
I have attached my logs.
Thank you.
P.S. this may or may not be related but if I try to go to https:// plex . tv in my browser I get a security error that the certificate belongs to bizzby . com (sorry for the weird syntax but I got an error that I can’t put links in a post.)
It appears you have a certificate in the sequence somewhere.
PMS does not allow or support a certificate to come between it and Plex.tv
auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
Feb 24, 2019 00:44:36.937 [0x7efccd3fe700] DEBUG - MyPlex: updating with 5 access tokens
Feb 24, 2019 00:44:37.010 [0x7efccebff700] ERROR - Error issuing curl_easy_perform(handle): 51
Feb 24, 2019 00:44:37.010 [0x7efccebff700] WARN - HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (@€ÁÍü~)
Feb 24, 2019 00:44:37.010 [0x7efccebff700] ERROR - Error parsing content.
Feb 24, 2019 00:44:37.043 [0x7efccebff700] ERROR - Error parsing XML.
Feb 24, 2019 00:44:37.227 [0x7efccfbff700] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Feb 24, 2019 00:44:37.846 [0x7efccfbff700] ERROR - Error issuing curl_easy_perform(handle): 60
Feb 24, 2019 00:44:37.846 [0x7efccfbff700] WARN - HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (SSL certificate problem: unable to get local issuer certificate)
Feb 24, 2019 00:44:37.847 [0x7efccfbff700] ERROR - Error parsing content.
Feb 24, 2019 00:44:37.847 [0x7efccfbff700] ERROR - Error parsing XML.
Feb 24, 2019 00:44:37.847 [0x7efccfbff700] DEBUG - Job running: '/usr/lib/plexmediaserver/CrashUploader' '--directory=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.14.1.5488-cc260c476' '--version=1.14.1.5488-cc260c476' '--platform=linux-ubuntu-x86_64 (3.10.0-957.5.1.el7.x86_64 (#1 SMP Fri Feb 1 14:54:57 UTC 2019))' '--serverUuid=e0a0c3ed6d35beaad5c68f5b3edc248bf4009cde' '--userId=coolguy_451@netzero.net' '--url=https://crashreport.plexapp.com'
This is why it cannot download the codecs.
Notice the “local issuer” part. This invalidated everything.
It appears to be a DNS issue. Using the default DNS from my ISP returned different results than those from Google’s DNS 8.8.8.8 so I switched the server and the client trying to play over to Google’s DNS then everything started working.
That’s interesting. I will keep that in my book of things to try.
I am surprised an ISP would mess with the DNS
I’m not sure of how the mechanics of AWS works but I imagine it’s something to do with that. Maybe the ISP caches the DNS too long or something and that throws it off. DNS would also explain why I would get the https ssl errors. I was actually getting redirected to the random other AWS hosted sites. So their cert didn’t match up with the site name in the browser (plex.tv)
