Unable to reach Plex UI
hello,
I have a NAS which I setup nginx as a reverse proxy to access various applications on it, including Plex. I recently upgraded plexmediaserver on my FreeBSD server. However, since I upgraded it, I’m unable to reach the Plex UI in a browser (http://mynas .domain.com/plex) after and I can’t connect with any Plex applications on my SmartTV or XBox One. I am able to access all the other applications that are hosted on the server through the nginx reverse proxy. i.e. http://mynas.domain .com/app1 and http://mynas.domain .com/app2.
The nginx config hasn’t changed:
location /plex {
proxy_pass
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
location /web {
proxy_pass https://localhost:32400;
I can verify that plexmediaserver is running on my server:
$ ps aux | grep plex
plex 656 0.0 0.6 350964 52568 - Ss Tue06PM 2:43.99 /usr/local/share/plexmediaserver/Plex_Media_Server (Plex Media Server)
plex 781 0.0 0.6 298028 45668 - SN Tue06PM 3:27.05 Plex Plug-in [com.plexapp.system] /usr/local/share/plexmediaserver/Resources/Plug-ins-a17e99e/Framework.bundle/Contents/Resourc
plex 798 0.0 0.2 209652 14584 - S Tue06PM 0:50.34 /usr/local/share/plexmediaserver/Plex DLNA Server
If I try to curl the URL, http:// mynas.domain .com/plex, on my server I get the following
$ curl mynas.domain .com/plex
curl: (7) Failed to connect to mynas.domain. com port 80: Connection refused
If I curl the localhost on the server with the port running Plex (curl localhost:32400), I get an XML output rather than HTML.
I’m not sure why I’m getting XML rather than the web UI for Plex. What would cause that to happen? Is it possible some permissions changed while I ran the update?
UC Browser Apk SHAREit Apk
