Plex WebUI not working anymore
Hello everyone,
my Plex server running on TrueNAS stopped working after restart.
In my current situation I have to turn off the Server over night and after todays start Plex wasn’t accessible anymore. I haven’t changed anything besides adding new media. The last “unusual” thing I did was updating my version but it worked as usual after that. I’ve read somewhere today that the update can cause problems.
So I did some testing and figured out that Plex was running because I could access my content through the Win10 and Android App, DLNA was also working.
My conclusion: WebUI is broken.
What I did so far:
  • restarting a few times
  • creating a new jail through TrueNas which did work( and also showed my stuff)
  • changing IP of the Jail
  • trying t manually start the UI but couldn’t find out how
I hope you can follow what I’ve written here.
In conclusion: I need help
using hosted or local web app? do both not work?
Hello thanks for the fast reply.
I’m sorry if I mix some things up but I’ll try to explain how I connect to my server.
I have plex running in a TrueNAS jail which I installed with the official plugin. ( so everything should be standard.)
I connect to that Jail IP and the port 32400.
That doesn’t work.
My friends connect to it with plex.mydomain.de.
This is done with Cloudflare and reverse proxy on a Pi.
This does also not work. My friends get the cloudflare error 502: Bad Gateway.
I hope this answers your question.
Are you using the TrueNAS plugin?
Or a standard jail with the plexmediaserver or plexmediaserver-plexpass pkg?
Because you can still get to the content, my first guess is that you’re hitting this issue, and need to add LD_LIBRARY_PATH to your rc script.
Otherwise please share what you get when you visit it locally. An error in the browser? Something else?
I’m using the Plugin Version.
Since i don’t have plex pass yet i assume i should edit the file thats just called “plexmediaserver”?
In this filed i couldn’t find the “export SCRIPTPATH…” line. Should i add both of them then? And where?
My file looks like this:
Maybe I’m barking up the wrong tree.
If it’s a fresh install of the plugin, it should already include the necessary lines, down around lines :59 and :60.
Can you share that file?
What version of Plex is installed?
pkg version -x plexmediaserver
or
strings /usr/local/share/plexmediaserver/Plex\ Media\ Server | egrep '[0-9]\.[0-9]{2}\.[0-9]\.[0-9]{4}-'
Can you restart Plex and then share /Plex Media Server/Logs/Plex Media Server.log?
OK Sorry I’m a bit of an Idiot today. The Console Window made it look like the file ended but it didn’t. Both lines are present.
The Version is 1.22.3.4392
Funny thing is if I copy the second command it tells me a different version: 1.23.2.4656-85f0adf5b
Here is the Log File
Plex Media Server.log (100.3 KB)
Have you also updated Plex manually or using PMS_Updater? I’m just curious about the version discrepancy.
What happens when you visit http://192.168.2.30:32400/web in a browser on that network?
I think it was PMS_Updater, but i’m not sure but it was definitely something similar.
Oh yeah i forgot to post the error, here it is:
This page isn’t working
192.168.2.30 didn’t send any data.
ERR_EMPTY_RESPONSE
Sign in on https://app.plex.tv/
Change SettingsNetworkSecure Connections from Required to Preferred.
Try http://192.168.2.30:32400/web again.
That error occurs when Chrome tries to use HTTP to load data from an HTTPS-only server. :slight_smile:
Oh yeaaah i remember now i was playing around in the settings to see if i can limit Bandwith usage and played around with other settings.
Thank you so much its working now. ^^
