Hello,
I am having an issue with this error as well. Running Server version 1.10.0.4523 on scheduled recordings. It is generating short files, if it records at all.
See earlier posts on log files, eg
Restart the server to get fresh log files
Reproduce the problem
Note down time and details of what failed
Collect the logs and upload with the details
Same here, See attached log. The 12/19/17 18:00 mark is an issue that I am having as described above.
Iām having this issue with regularity as well and Iām running the windows release from yesterday. In think itās more prevalent when there are back to back recordings, the second recording is the one that fails. Is it possible that because Iām removing commercials itās locking up the tuner and the second recording fails? I have the HDHOMERUN Quad Connect so available tuners isnāt an issue, I had 3 available.
Same here, running 1.11.0.4666. Cannot get it to record a thing. Very disappointed. The live tv works OK but kodi is significantly clearer running. They have a long way to go on this functionality before it is usable as far as i can tell. Not u=sure if there are any developments yet this year. I would love to be able to just use Plex for everything.
I am having this same problem - āTHERE WAS A TRANSCODER ERRORā every time I try to record. Any help you can provide would be appreciated. I have tried all of the above. Than you.
I have been looking at the logs and what I can see is errors when trying to get the status from the usb connected dvr
e.g.
Jan 06, 2018 09:57:32.710 [4328] WARN - [E] web_service_t::get_device_status. get_device_info returned error for device dvb#bda#0#@device:pnp:\\?\usb#vid_07ca&pid_0837&mi_01#7&2a365b92&0&0001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{e01e1072-3df3-4c23-b99f-6a27a7cc7cd2}
Jan 06, 2018 09:57:32.710 [4328] WARN - [E] web_service_t::process_start_channel. get_device_status failed for device dvb#bda#0#@device:pnp:\\?\usb#vid_07ca&pid_0837&mi_01#7&2a365b92&0&0001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{e01e1072-3df3-4c23-b99f-6a27a7cc7cd2}
and at that time the transcoder fails
Jan 06, 2018 09:57:32.725 [2320] ERROR - [Transcoder] http://127.0.0.1:32600/devices/dvb%23bda%230%23%40device%3apnp%3a%5c%5c%3f%5cusb%23vid_07ca%26pid_0837%26mi_01%237%262a365b92%260%260001%23%7b71985f48-1ca1-11d3-9cc8-00c04f7971e0%7d%5c%7be01e1072-3df3-4c23-b99f-6a27a7cc7cd2%7d/media/triplet%3A%2F%2F0%3A2491%3A3?param=%3C%3Fxml%20version%3D%221%2E0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3Ctunedata%3E%3Ctt%3E8%3C%2Ftt%3E%3Cdq%3E0%3C%2Fdq%3E%3Cdr%2F%3E%3Cfr%3E34%3C%2Ffr%3E%3Cmd%3E0%3C%2Fmd%3E%3Csr%3E0%3C%2Fsr%3E%3Cpl%3E0%3C%2Fpl%3E%3Clf%3E0%3C%2Flf%3E%3Cl1%3E0%3C%2Fl1%3E%3Cl2%3E0%3C%2Fl2%3E%3Cls%3E0%3C%2Fls%3E%3Cpp%3E0%3C%2Fpp%3E%3Chz%3E0%3C%2Fhz%3E%3Cin%3E0%3C%2Fin%3E%3Cfc%3E0%3C%2Ffc%3E%3Ct%3E2491%3C%2Ft%3E%3Cn%3E0%3C%2Fn%3E%3Cs%3E3%3C%2Fs%3E%3Cen%3E0%3C%2Fen%3E%3C%2Ftunedata%3E%0A: Server returned 404 Not Found
I will discuss with the devs - but it looks some issue with the usb connection
Is the user account the Plex Media Server runs in an admin account? It should not be necessary - but just in case it has a bearing
Further to my earlier reply, could you tell me what make / model the DVR is and also confirm that it works on the usb through other software.
It was not clear if you were saying livetv via plex was working but recording was not - you mentioned kodi so I was not sure exactly what you were saying
So at the time when we get this usb error on recording, does livetv work on plex ? Could you try both after a reboot and note down time when each was tried and attach logs zip
Also after the failure, can you confirm that it works through other software in that usb connection - also is it possible to try it with other tuner software
I was getting some random issues where a show would record but would then throw out this error
āAn error occurred while postprocessing the recordingā but now I too am getting this āthere was a transcoder errorā on four consecutive shows today. Iām running Version 1.11.0.4666 as well. Any further insight would be appreciated.
I too am having the same issues. Currently on Version 1.11.0.4666 but have been experiencing frequent recording issues on recent releases. Getting to the point PLEX DVR is too unreliable to be a daily driver and I have had to resort to using other DVR software packages to ensure I get good recordings of problematic shows. Really hope this gets sorted out soon as I like PLEX being the center of ALL my media needs.
Add my name to the list of folks getting the transcoding error message. I, too, like Plex quite a bit, but I would like to be able to use the DVR function.
OK. I got it to record. āFrom Here to Eternity,ā which totally rocks. I clicked on the Plex Media Server icon. Who knows if that reset the thing or not, but now it works. My guess? It will probably stop working again. But I am experimenting with it to see if I can get it to continue working.
I have the same problem āThere was a transcoder errorā on every record. My tuner is a HDHomeRun, 4 tuners and I use Plex server version 1.12.3.4973. I have this problem since one of the latest updates. Before, it was working.
Need new fresh logs of the problem on current beta please
May also require getting a capture from the tuner - but need to see the logs first
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
I am running into the same issue with a HDHomeRun Quattro. I am running Plex 1.12.3.4973 on FreeBSD 11.1.
I have attached my current log set.
I keep seeing this in the logs:
Apr 25, 2018 00:16:48.719 [0x80accb800] ERROR - [Transcoder] http://127.0.0.1:32400/livetv/sessions/0bdf6f49-2817-443c-884d-805b633ce2ae/8a098415-977f-4293-aa78-d5b0d4eddfcd/index.m3u8?offset=-1.000000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply
Apr 25, 2018 00:16:48.719 [0x80accbd00] DEBUG - Jobs: '/usr/local/share/plexmediaserver/Plex Transcoder' exit code for process 14458 is 1 (failure)
Apr 25, 2018 00:16:48.719 [0x80acccc00] DEBUG - DVR:Grabber: Recording for 'The Tonight Show Starring Jimmy Fallon - E114 - Kevin James; Questlove; Sigrid' stopped with status error.
Apr 25, 2018 00:16:48.722 [0x80aa5a600] DEBUG - DVR:Subscription: Failed to resolve subscription for episode 'grandparentGuid: com.gracenote.onconnect://show/9898935 grandparentThumb: http://tmsimg.plex.tv/assets/p14578558_b_v5_aa.jpg grandparentTitle: The Tonight Show Starring Jimmy Fallon grandparentYear: 2014 guid: com.gracenote.onconnect://episode/EP017211070968 index: 114 originallyAvailableAt: 2018-04-24 parentIndex: 5 title: Kevin James; Questlove; Sigrid type: 4 year: 2018' to library item
@bremen242 said:
I am running into the same issue with a HDHomeRun Quattro. I am running Plex 1.12.3.4973 on FreeBSD 11.1.I have attached my current log set.
Apr 25, 2018 00:16:48.719 [0x80accb800] ERROR - [Transcoder] http://127.0.0.1:32400/livetv/sessions/0bdf6f49-2817-443c-884d-805b633ce2ae/8a098415-977f-4293-aa78-d5b0d4eddfcd/index.m3u8?offset=-1.000000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply Apr 25, 2018 00:16:48.719 [0x80accbd00] DEBUG - Jobs: '/usr/local/share/plexmediaserver/Plex Transcoder' exit code for process 14458 is 1 (failure) Apr 25, 2018 00:16:48.719 [0x80acccc00] DEBUG - DVR:Grabber: Recording for 'The Tonight Show Starring Jimmy Fallon - E114 - Kevin James; Questlove; Sigrid' stopped with status error. Apr 25, 2018 00:16:48.722 [0x80aa5a600] DEBUG - DVR:Subscription: Failed to resolve subscription for episode 'grandparentGuid: com.gracenote.onconnect://show/9898935 grandparentThumb: http://tmsimg.plex.tv/assets/p14578558_b_v5_aa.jpg grandparentTitle: The Tonight Show Starring Jimmy Fallon grandparentYear: 2014 guid: com.gracenote.onconnect://episode/EP017211070968 index: 114 originallyAvailableAt: 2018-04-24 parentIndex: 5 title: Kevin James; Questlove; Sigrid type: 4 year: 2018' to library item
Does this only arise when attempting to stream Live TV whilst a recording is going on the same channel ? What Plex client app is being used ? It is IP 10.3.2.55
I seem to have hit the same issue with the āDVR asked to stop recordingā Iām on the latest Plex version⦠Iām not sure if it was a CPU overload or what the issue could have been but me and the wife were watching a Plex recorded show and my wifeās parents were streaming another show at the same time this show was recording from the HDHomeRun Prime. Nobody was watching live tv when this happened so the only tuner being used was the one Plex was using to record until it failed ~30 minutes into it.
āApr 25, 2018 21:31:11.443 [7592] DEBUG - DVR:Recorder: Asked to stop recording āThe Americans - E5 - The Great Patriotic Warā.ā
Apr 25, 2018 00:16:48.719 [0x80accb800] ERROR - [Transcoder] http://127.0.0.1:32400/livetv/sessions/0bdf6f49-2817-443c-884d-805b633ce2ae/8a098415-977f-4293-aa78-d5b0d4eddfcd/index.m3u8?offset=-1.000000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Server returned 5XX Server Error reply Apr 25, 2018 00:16:48.719 [0x80accbd00] DEBUG - Jobs: '/usr/local/share/plexmediaserver/Plex Transcoder' exit code for process 14458 is 1 (failure) Apr 25, 2018 00:16:48.719 [0x80acccc00] DEBUG - DVR:Grabber: Recording for 'The Tonight Show Starring Jimmy Fallon - E114 - Kevin James; Questlove; Sigrid' stopped with status error. Apr 25, 2018 00:16:48.722 [0x80aa5a600] DEBUG - DVR:Subscription: Failed to resolve subscription for episode 'grandparentGuid: com.gracenote.onconnect://show/9898935 grandparentThumb: http://tmsimg.plex.tv/assets/p14578558_b_v5_aa.jpg grandparentTitle: The Tonight Show Starring Jimmy Fallon grandparentYear: 2014 guid: com.gracenote.onconnect://episode/EP017211070968 index: 114 originallyAvailableAt: 2018-04-24 parentIndex: 5 title: Kevin James; Questlove; Sigrid type: 4 year: 2018' to library itemDoes this only arise when attempting to stream Live TV whilst a recording is going on the same channel ? What Plex client app is being used ? It is IP
10.3.2.55
It happens if I try to watch live TV, record live tv, or record and watch the same show. Basically, any time that I try to watch TV, it does that. It also does that if I try to play an mkv file as well.
The client was the built-in web application on the server. I was using Firefox.
@GloverMainAccount said:
I seem to have hit the same issue with the āDVR asked to stop recordingā Iām on the latest Plex version⦠Iām not sure if it was a CPU overload or what the issue could have been but me and the wife were watching a Plex recorded show and my wifeās parents were streaming another show at the same time this show was recording from the HDHomeRun Prime. Nobody was watching live tv when this happened so the only tuner being used was the one Plex was using to record until it failed ~30 minutes into it.āApr 25, 2018 21:31:11.443 [7592] DEBUG - DVR:Recorder: Asked to stop recording āThe Americans - E5 - The Great Patriotic Warā.ā
There was a tuner stream capture error just before that
Apr 25, 2018 21:31:10.562 [9412] ERROR - [Transcoder] http://10.0.0.140:5004/auto/v631: Unknown error
Could be signal issue / tuner issue.
I will try and find out if you can get more info about the error with extra transcoder logging - assuming it happens again
It happened again last night⦠this time while recording āOnce Upon a Timeā - The recording stopped after about a minute into the show. Nobody was watching anything on Plex or using the HDHomeRun at the time as we were out with her parents.
Apr 27, 2018 19:00:01.297 [3132] DEBUG - DVR:Grabber: Going to record for 3959 seconds, final URL is http://10.0.0.140:5004/auto/v613
Apr 27, 2018 19:00:01.297 [3132] DEBUG - DVR:Grabber: Setting timer to stop grab of āOnce Upon a Time - E19 - Flower Childā in 3959 seconds.
ā¦
Apr 27, 2018 19:00:02.299 [4720] ERROR - [Transcoder] [mpeg2video @ 0383a280] Invalid frame dimensions 0x0.
Apr 27, 2018 19:00:02.330 [4724] ERROR - [Transcoder] [mpeg2video @ 0383a280] Invalid frame dimensions 0x0.
ā¦
Apr 27, 2018 19:01:04.260 [7540] DEBUG - DVR:Recorder: Asked to stop recording āOnce Upon a Time - E19 - Flower Childā.
Apr 27, 2018 19:01:04.260 [7540] DEBUG - DVR:Recorder: Stopping transcode session.
Apr 27, 2018 19:01:04.260 [7540] DEBUG - Killing job.
Edit and removed my logs: Weāve gone ahead and started to use WMC to record things until this clears up. We had a few more shows that cut off tonight⦠Keep up the good work though! We canāt wait to see the better guide for Plex.
