Unable to upload posters for some movies "*.bunlde" not a directory
I can’t upload posters for some movies. I get an error.
Log says this:
Jan 07, 2020 14:10:54.233 [0x7fa4d0e31700] ERROR - Exception handled: boost::filesystem::create_directories: Not a directory: “/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Metadata/Movies/b/f232d5805edf58170439523306c3a503d48b9e5.bundle/Uploads”
And indeed f232d5805edf58170439523306c3a503d48b9e5.bundle is an xml file:
<?xml version='1.0' encoding='utf-8'?>
While other *.bundle assets in this directory are directories themselves with more files and directories underneath.
Can I delete the .bundle file, will Plex recreate it? I tried refreshing metadata and restarting the server but it did not help
Sadly not by itself.
I recommend, that you install ExportTools, and then run an export on your movie library at level 666
See: Movie Export Level · ukdtom/ExportTools.bundle Wiki · GitHub
After that, search the CSV/XLSX file for f232d5805edf58170439523306c3a503d48b9e5.bundle to identify the movie, and do a Plex Dance on it
See: The Plex Dance ™
And if you already knows what movie, simply do the Plex Dance
It worked, thanks!
