Unauthorized plex media server
Server Version#: 1.19.4.2854-25d22e39e
Client Version - web app, RokuTV (6.5.4.6365-98e5fa548-Plex)
Everything was running fine on my Plex until I signed out on my RokuTV.
Symptoms:
  • When I sign my RokuTV back in I can’t see my plex media server.
  • I can’t see the server or the Server tab (in Settings menu) when I open plex web app on the laptop running the server.
  • My daughter’s account (set to share on local network only) can see the server, all the media, etc. - works fine.
What I have tried:
  • Reboot the server - no help
  • log out and log back in - no help
  • log in to the server using local IP address (http://localhost:32400/web/index.html - no help
  • allow unsecured connections - no help
Under all the above attempts the Settings>Server tab does not appear.
Any suggestions on where to go from here are appreciated.
Did you look under the “more” tab at the bottom?
Blockquote Did you look under the “more” tab at the bottom?
Thanks for responding!
On the Roku app there is a “More” tab, clicking it shows the server’s name and gives a “Sign in” or “Re-try connection” option. When I click “Sign In” I am given a code to enter at a website, entering the code takes me back to the user selection menu, click-rinse-repeat. When I select my daughter as the user, the server appears, all content is available.
On the Plex-Web interface there is no “More” tab, there is a “Your Media” tab at the bottom of the left side menu. Clicking that tab simply offers the opportunity to “Get Plex Media Server” - something I have obviously already done and am running correctly or my daughter’s user account wouldn’t be able to access the server.
Thanks again for any further suggestions!
Screenshots please. I’m not following.
A picture is worth many awkward words …
On the computer running the server, using the plex web interface and logged in as my user:
On the same computer, using the plex web interface and logged in as my daughter’s user:
On the RokuTV, logged into the app as my user, after clicking the “More” tab at the bottom:
On the RokuTV, logged into the app as my daughter’s user, after clicking the “More” tab at the bottom:
Hope that explains things better!
Thanks. Looks like somehow your server isn’t quite linked up properly to your account. Try this https://support.plex.tv/articles/204281528-why-am-i-locked-out-of-server-settings-and-how-do-i-get-in/ then reclaim your server.
That worked! Thanks so much for your help with this.
