so i downloaded zip, installed python, openssl, created cert, copied them, imported them, changed DNS to the python running computer, input plex media server IP (its the same)
plex version 0.9.11.4
ATV3 7.0.2
machine is windows8, and this is what i get when try to access the ip from other computers
port 80:
Error response
Error code 403.
Message: Not Serving Client 192.168.88.151.
Error code explanation: 403 = Request forbidden -- authorization will not help.
port 443:
192.168.88.25 uses an invalid security certificate.
The certificate is not trusted because it is self-signed.
The certificate is only valid for trailers.apple.com (Error code: sec_error_unknown_issuer)
here is my config:
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.88.25
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = C:\PlexConnect\assets\certificates railers.pem
loglevel = High
logpath = .
log:
12:20:16 PlexConnect: started: 12:20:16
12:20:16 PlexConnect: Version: 0.4-dev
12:20:16 PlexConnect: Python: 2.7.9 (default, Dec 10 2014, 12:24:55) [MSC v.1500 32 bit (Intel)]
12:20:16 PlexConnect: Host OS: win32
12:20:16 PlexConnect: PILBackgrounds: Is PIL installed? False
12:20:16 Settings: getsetting enable_plexconnect_autodetect=True
12:20:16 PlexConnect: IP_self: 192.168.88.25
12:20:16 Settings: getsetting hosttointercept=trailers.apple.com
12:20:16 Settings: getsetting enable_dnsserver=True
12:20:16 DNSServer: started: 12:20:16
12:20:16 Settings: getsetting port_dnsserver=53
12:20:16 Settings: getsetting ip_dnsmaster=8.8.8.8
12:20:16 Settings: getsetting prevent_atv_update=True
12:20:16 DNSServer: ***
12:20:16 DNSServer: DNSServer: Serving DNS on 192.168.88.25 port 53.
12:20:16 DNSServer: intercept: ['trailers.apple.com'] => 192.168.88.25
12:20:16 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
12:20:16 DNSServer: forward other to higher level DNS: 8.8.8.8
12:20:16 Settings: getsetting enable_webserver_ssl=True
12:20:16 WebServer: started: 12:20:16
12:20:16 Settings: getsetting port_webserver=80
12:20:17 WebServer: ***
12:20:17 WebServer: WebServer: Serving HTTP on 192.168.88.25 port 80.
12:20:17 WebServer: started: 12:20:17
12:20:17 Settings: getsetting port_ssl=443
12:20:17 Settings: getsetting certfile=C:\PlexConnect\assets\certificates railers.pem
12:20:17 WebServer: WebServer: Serving HTTPS on 192.168.88.25 port 443.
12:20:19 DNSServer: DNS request received!
12:20:19 DNSServer: Source: ('192.168.88.30', 54736)
12:20:19 DNSServer: Domain: trailers.apple.com
12:20:19 DNSServer: ***intercept request
12:20:19 DNSServer: -> DNS response: 192.168.88.25
12:20:35 PlexConnect: Shutting down.
12:20:36 WebServer: Shutting down (HTTP).
12:20:36 WebServer: Shutting down (HTTPS).
12:20:39 DNSServer: Shutting down.
12:20:39 PlexConnect: shutdown
help :P
