Undefined error -2140536828 on PS4 after update to 1.3.3.3148
So is there yet any fix for this? I’m stunned its not fixed yet
I managed to reinstall an old 0.9 version which helped previously, but right now the 0.9 version doesn’t connect to my server anymore (I thought it was worthwhile trying the latest update once more… I was wrong)
ps. like others, the streaming works fine when I do either of the following:
  • play without subtitles
  • set the Streaming quality on remote access to ‘original’
Hi, I got the same issue, and playing TV shows or movies without subtitles is not a solution, but a workaround. So Plex, could you please fix this.
Streaming quality remoote: roiginal doesn’t work for me :frowning:
the error -2140536828 is SCE_AVPLAYER_ERROR_NOT_SUPPORTED which is a PS4 error that means the file is not supported in some manner.
I am assuming all of your servers can transcode correct? subtitles need to be burned in
can you enable logging in PS4 app then grab server logs after the error appears
Hm, I can’t reproduce the error anymore. I’ve tried changing the settings back, but now it plays files with subtitles without trouble. I’ll upload logs if the error appears again.
Hello,
I am trying to find a resolution to this “Undefined error -2140536828”. I’m experiencing this issue on my PS4 as well. It appears the short-term fix is to turn off subtitles; however, I am unable to find the menu option in Settings to turn them off. There is an option for subtitle size, but no option to turn them on or off.
When I try turning off the subtitles from within a started movie or show, I still receive the Undefined error -2140536828.
Does anyone have insight on how I can resolve this undefined error issue?
Thank you!
Plex version 3.80
PS4 version 01.55
I too have exactly the same problem with subtitles on PS4. Everything works fine, but once I turn subtitle on for any video, I get this “unknown” error.
I tried SRT and VTT and they both gave the same error. I think it’s a problem with transcoding, because the PS4 plays native files very well. When Plex transcodes the files to burn subtitles on the picture, it streams unsupported video format to the PS4.
The Plex player has just been installed on the PS4 for the first time, so I suppose I have the latest version. My server is running CentOS 7 and Plex Server ver. 1.9.1.4272.
Hello,
I believe my error was due to a “double NAT” situation. I removed the router and plugged my PS4 directly into the modem, and I no longer have this issue.
Best regards.
It’s not related to transcoding because if I force a lower quality, that forces transcoding and the video plays correctly: it only happens when enabling subtitles, both in original quality and in lower ones.
I’m getting this error when I try to put subtitles on my shows, too. Has anyone reliably fixed it?
nope and i think it’s safe to think that there won’t be any in the near future. just to set expectation and not hopeful
I faced this same issue with my Plex Media Server on shield, things worked fine when I was using my PC as my PMS.
Some how deleting logs pretty much was my fix, other than playing with some settings here and there that initially made no sense through trial and error.
I faced pretty much about the same issue everyone else here did with every other device but the PS4 working, To re-cap though I went through an enabled logs on the ps4 in order to re-produce the issue and try and see what could be going on.
Upon doing so, I realized my PMS logs were flooded so deleted all of em. Went to re-produce issue… content started playing fine with subtitles no more error.
Baffled by this I had a (remote) friend try his PS4 and he was met with same result any media was now working fine. No conversion of media or optimization and hardly any server changes.
The only other things I can think of that I had done was, I turned off and back on the hardware transcoder for trial and error purposes and I had also noticed at the time that my library had finished ‘refreshing’ meta-data once things started to work. I also deleted all old devices under my linked devices but this didn’t seem to have any immediate impact.
Hope this helps someone else.
I got the error again and think I have some server logs to post. Where do I send them to? Or would you like me to paste them here?
i also had the same error message all of a sudden in the middle of a video, i changed my subs to small, restarted the video and it worked, then i changed the subs back to normal size and now everything is working fine again
The fix seems to be all over the map, I had changed my server to show subs and select them automatically, changing that back to manually selecting subs fixed the issue for me. Oh well no subs for me tonight at least.
Oh forgot to mention, Synology NAS here too.
Restarting the server fixed it for me. That’s weird, My first thought was something weird about space for the transcode but I had plenty of room. I’d love to know what the issues actually is.
Not saying this is a fix for everyone as it looks like this code relates to multiple errors but my cache drive was full on the PMS side. Once i free’d up some space the error went away.
PMS running on docker here - deleting the codecs file seemed to do it for me…
/Container/Plex/Library/Application Support/Plex Media Server/Codecs
Same problem for me, latest server on ubuntu, and plex on ps4 not play any video with subtitles. Turn off subtitles works, but i need subtitles because I’m not good in english.
