Undocumented functionality and Tips & Tricks
I've posted a small document on Google, where I'll start to collect info regarding development towards the mighty Plex.
It's a sister document to this one:
https://forums.plexapp.com/index.php/topic/87324-missing-from-the-official-plugin-documentation/?p=505931
And can be found here:
https://docs.google.com/document/d/1hhLjV1pI-TA5y91TiJq64BdgKwdLnFt4hWgeOqpz1NA/edit#heading=h.k434y18gzsvt
Check it out, and do chime in with improvements, suggestions etc.
/Tommy
Edit: 01 Aug 2014: Updated with info on how to find extra's
Edit: 22 feb 2014: Updated with info about how to access the media folder for an item via http
Edit: 17 feb 2014: Updated to use the http api instead of urllib when setting prefs
Edit: 9 feb 2014: srazer found out a way to update more pref settings in one go
Edit: 2 feb 2014: Updated with Language Api
Edit: 26 jan 2014: Updated with Prefs tip
Edit: 22 jan 2014: Updated links in the document
Updated to reflect the new website regarding links, and added how to reset user preferences on the fly to it's defaults
Look here
/Tommy
Updated with a tip from srazer about viewing the preferences.
Look here
Thanks Chris
Updated with some info regarding Language API
Look here
Look here
Updated with info on how to locate the media folder for an item, via the http API
When I'm trying to dev a metadata agent, I didn't succeed in exploring the content of media and metadata objects.
I've tried to print in the logs the result of dir(metadata) for exemple an it didn't work.
Is there a way to explore this type of object in a plugin ?
Not related to this thread, IMHO.....Leave, and create a new root post
/T
The answer could be log in the tricks section ? Don't you think ?
A question, nope....An answer, yes...and you asked a question, or?
/T
OK my bad I didn't understood the rule of this post ;-)
Just updated my little doc with info on how to get to the extra's
Find the link in the first post
Happy Plexing
Tommy
Hi Dane,
After digging here https://code.google.com/p/plex-api/w/list and your undocumented stuff, I still cannot find the answer to my question : subtitles... where can I find them ?
With the HTTP API I crawled the whole tree... nothing. I scanned the database... nothing.
I would like to write a little script to get the status for my tv shows : are the subtitles yet downloaded or not. If they are not then I could launch an agent to refresh the metadata and try again to get them...
Any idea where I should look ?
Regards,
matt.
Not relevant for this thread, and answered by others in the OTHER  :( post you made about this
