Unknown Airing - UK EPG
I have it now also with 1.22.0.4163
My bad I just realized this was about UK EPG. I live in the US this probably isn’t related.
No worries - I think you may be right though - the problem appears to be with the “HD channels only” filter.
So I thought this was just a display issue with selecting HD channels only but it seems that Plex has stopped recording in HD!!!
Please fix this ASAP!
+1 to this issue.
DVR is set to Local Broadcast Listings (STV West region) and all of my recordings are set to ‘Prefer HD’. They are all recording in SD.
I’m going to change my settings to HD only and see what happens! Who wants to watch programs in fuzzy vision!!
Hi, so with it set to HD Only it didn’t record anything at all! So I set it back to Prefer HD and then changed the channel from Any to the HD channel and it ignores that setting and still records the SD channel!! So quite a few bugs here I think, the logs hopefully show what’s going on and also will show the other issue I have with the playback of recorded files playing in slow motion when the broadcast switches to Dolby 5.1 sound!
Plex Media Server.4.log (10.0 MB) Plex Media Server.5.log (10.0 MB) Plex Media Server.3.log (10.0 MB)
No, don’t do that. Limit it to only record from the HD channel instead
:slight_smile:
That’s exactly what I did! Probably didn’t explain it very well though!! But like I said it doesn’t work!
When you say it didn’t work, do you mean that it showed in DVR Schedule that it was going to record from the SD channel or did it actually record the SD channel when it actually recorded it?
I have found that sometimes the DVR Schedule shows the wrong channel or time if I edit a recording to change the channel or airing time on an existing recording. If I cancel the recording and then reschedule it, making sure to set the correct channel or airing time before saving it shows correctly in the schedule.
