Unmatched/Missing integrated
I just went from a Boxee to Plex. Plex is alot better (and more expensive), but almost worth it.
I have a NAS running PMS, and my technical skills are not the best, therefore, installing an unsupported channel is difficult and challenging. Thats why i chose plex and not xbmc.
Plex really needs a tool that tells the users what files are not imported to Plex. It shouldn't be that hard, and the coding is there in the unsupported channel. The fix incorrect match tool is excellent, but with over 4.000 movies, its hard to go through all the folders and count if they are all there.
https://forums.plex.tv/topic/87745-find-unmatched-items/
I've seen that, and scrolled through endless forums, but I cannot find a way to install either the unsupported appstore, nor the app itself.
I've tried using ssh on my mac, but I can't find the directory to put the app into. I had the PMS on a mac mini, and then I got it to work, but the app itself is not really good. I know there are a few missing videos, but the app says everything is ok.
Thats why I think this is a feature that should be integrated into Plex. Its a very basic request to be able to see whats missing/not matched. What is the purpose of this program if you can't know for sure that all your movies are in here, either as unmatched or match, and that I need a 3rd party "not supported" app/channel to see this?
https://support.plex.tv/hc/en-us/articles/201187656-How-do-I-manually-install-a-channel-
you can see why it isn't an official channel in the duplicate of your request
https://github.com/ukdtom/Plex-FindUnmatched.bundle/wiki/Install
/Tommy
Most likely due to the fact, that the medias is identified, but wrongly.....
As such, "Movie X" shows in Plex as "Movie Z"
Sadly, there's nothing I can do about that part....
One has to follow the naming guide to the letter...
(See my signature)
/T
Early 2021 clean-up: implemented (filter library by unmatched/duplicates)
