Server Version#: Latest docker (3 days ago) I can’t see the version
Player Version#: All
My cache drive was running out of space, it was around 80% utilized and I decided to add in another drive and create a pool in single (jbod) mode. I followed instructions in one of spaceinvaders vids. The existing cache drive is 256gb, new drive is 500gb. Everything went find with the balance command once I added the new drive and I spot checked some dockers and a VM to make sure all was good. I discovered last night that my plex image was failing. I tried to reinstall the image, the image successfully was reinstalled, however, the same problem occurs.
I have attached the diags from the server, let me know if there is something that sticks out that I can fix.
Thanks for the helpgalactus-diagnostics-20200201-0929.zip (119.1 KB)
