Cache drive ran out of space. I made space, but Plex Library not showing up
Server Version#: Unraid 6.8.2
Player Version#: 4.22.3
Hi guys, I run Plex in a docker in Unraid and my cache drive that has the appdata, etc. went down to 2gb recently. I don’t know if this is the reason, but all of a sudden Plex could not find my library, so I deleted some things on the cache (ISOs, etc.) to open up some space to 40gb. This did not fix the problem sadly. This is the log below:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Critical: libusb_init failed
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
