Hi
Pretty new to Plex and Unraid, I’ve built a small music sharing system, everything was working fine and now I’m unable to to get into the plex webUI. Basically it saying refused to connect.
Has anyone had this happen before, any work arounds or anything I should try or do.
Cheers
Plex logs -
text error warn system array login
/config/Library/Application Support/Plex Media Server/Preferences.xml:1.1: Document is empty
Failed to load preferences at /config/Library/Application Support/Plex Media Server/Preferences.xml
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
