Unsync the web interface between multiple servers?
Server Version#: 1.18.4.2171
Player Version#: 4.12.3
Is there a way to “unsync” the web interface from the user profile on each server so when I pull up the Plex interface using the local IP number of a server it doesn’t show all the libraries and DVR service from the other DVR?
Currently if I make changes to the pinned libraries on one DVR, it seems to sync across to the other DVR when I log in directly on that DVR.
It would be nice if there was an option to just show that DVR’s libraries when logging in directly to that DVR’s IP address. Maybe have a “local” user that is only visible in the server’s web interface when accessing it’s IP directly.
If I understand your question correctly, you can disable the synchronization of web client settings by selecting the following option in Settings -> (Plex Web) General on each client:
Then you should be able to log in to the local client on the server and reset customization. That will allow you to pick your default server and libraries again for that client.
Thanks. That was what I was looking for.
I didn’t seem to have the problem until this last upgrade. I don’t know if they reset the defaults during the upgrade or what.
