I successfully updated to El Cap - everything working fine on PlexConnect, except for the update button. It shows there is an update available, but if I click it, the blue updating line appears and just sits there.
Is this an issue that others are getting? Do I need to change anything?
Sorry I should have mentioned that it’s the Update Button on OpenPlex that isn’t working. I’ve let it run for at least 12 hours with no update - any thoughts?
Look in the openplex topic last few pages. Disable system integrity via OS X recovery mode then rerun the installer then it will work properly.
Hi Wahlman.j - just seen that…
Sorry to be a pain - Thanks very much!
All working fine now thanks very much
