Update Issues on WD Ex2 Ultra - 1.40.4.8679 and now 1.41.0.8994
I am running Plex on a WD Ex2 Ultra – updates are downloaded and installed manually and I manage my content via a Plex App on Windows 11 (64Bit).
Occasionally in the past I have had minor issues with updating the Server App but I have always managed to find a way around it. However with 1.40.4.8679 and now 1.41.0.8994 when I go into the Windows 11 App to check if everything is OK the connection with my server has been lost. The Plex updates seem to install OK but even if I reboot the NAS I can’t regain access to the Server (NAS). If I roll back to 1.41.1.9057 then everything works fine again.
This is not an urgent issue as everything is working OK and I primarily use my NAS for non Plex applications.
I’m just checking here.
I have the same problem, and have had it since update 1.41.7.9799.
All updates since that one make my NAS disks disappear on the network. But if I jump back to 1.41.6.9685, everything works again.
I’m running Mac iOS.
It’s MEGA frustrating, and no help can be found.
Thomas
I just found this post. It worked for me. Try it.
