Hi all
I am trying to update that file
PlexMediaServer-1.21.2.3939-3945797bd-armv7hf_neon
to my Synology.
It says wrong format contact the developper.
Downloaded here: https://downloads.plex.tv/plex-media-server-new/1.21.2.3939-3945797bd/synology/PlexMediaServer-1.21.2.3939-3945797bd-armv7hf_neon.spk.
Maybe I was missleaded by the x18 series?
Get the same error when using this one: Intel 64-bit (DSM 6.0 and newer).
It does not match.
What do you mean by “If the values do NOT match, then keep downloading the package until they do match.” When will they match?
Tried with IE. Same effect.
Moderator: Image edited to remove the serial number
Sorry for that. I was maybe misleaded by this link which points here: https://www.plex.tv/media-server-downloads/.
That link worked fine: https://artifacts.plex.tv/plex-media-server-experimental/1.21.1.3906-b0c7a97d9/synology-dsm7/PlexMediaServer-1.21.1.3906-b0c7a97d9-x86_64_DSM7.spk.
