Update Plex manually
Server Version#: Version 1.12.1.4885
Player Version#: LG TV
I’m trying to update Plex but Errors were encountered while processing.
root@helios4:~# sudo apt install plexmediaserver
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
plexmediaserver
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/71.4 MB of archives.
After this operation, 185 MB of additional disk space will be used.
(Reading database … 48291 files and directories currently installed.)
Preparing to unpack …/plexmediaserver_1.18.8.2527-740d4c206_armhf.deb …
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.18.8.2527-740d4c206) …
dpkg: error processing archive /var/cache/apt/archives/plexmediaserver_1.18.8.2527-740d4c206_armhf.deb (–unpack):
trying to overwrite ‘/usr/sbin/start_pms’, which is also in package plexmediaserver-installer 1.12.1.4885-1046ba85f-1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@helios4:~#
This removed the old plexmediaserver-installer and installed plexmediaserver but plex stopped working :frowning:
sudo apt remove plexmediaserver-installer
I tried to go to https://www.plex.tv/desktop and it didn’t work so I thought that something was wrong, I just forgot to go to my local ip and setup plex first.
