Here is the error message I get when trying to install Plex:
mark@nas-64:~$ sudo apt-get install plexmediaserver
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
plexmediaserver
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 0 B/103 MB of archives.
After this operation, 226 MB of additional disk space will be used.
Selecting previously unselected package plexmediaserver.
(Reading database … 103010 files and directories currently installed.)
Preparing to unpack …/plexmediaserver_1.13.9.5456-ecd600442_amd64.deb …
Unpacking plexmediaserver (1.13.9.5456-ecd600442) …
Processing triggers for mime-support (3.60ubuntu1) …
Processing triggers for ureadahead (0.100.0-20) …
Processing triggers for systemd (237-3ubuntu10.4) …
Setting up plexmediaserver (1.13.9.5456-ecd600442) …
Created symlink /etc/systemd/system/multi-user.target.wants/plexmediaserver.service → /lib/systemd/system/plexmediaserver.service.
Job for plexmediaserver.service failed because the control process exited with error code.
See “systemctl status plexmediaserver.service” and “journalctl -xe” for details.
dpkg: error processing package plexmediaserver (–configure):
installed plexmediaserver package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
plexmediaserver
E: Sub-process /usr/bin/dpkg returned an error code (1)
What would you suggest to get Plex on my server?
