Updates fail to apply
Server Version#: 1.15.1.710
I’m running Ubuntu 18.10 (GNU/Linux 4.18.0-16-generic x86_64). When I run “apt-get update”, I get the message mentioned in multiple other threads in the forum about “Conflicting distribution: https://downloads.plex.tv/repo/deb public InRelease (expected public but got ).” My problem is that all of those basically say to ignore the warning, go ahead and perform “sudo apt-get upgrade” and all will be fine. However, nothing is actually upgrading / updating and the client continues to ask me to install the update to 1.15.1.791. I made sure that the contents of /etc/apt/sources.list.d/plexmediaserver.list are “deb https://downloads.plex.tv/repo/deb public main” as prescribed by the other threads on the topic. So my question is: how do I upgrade PMS to 1.15.1.791 from 1.15.1.710 as requested by the client if apt-get upgrade isn’t actually seeing the changes to be made?
Rephrasing: on Ubuntu 18.10, after ensuring that /etc/apt/sources.list.d/plexmediaserver.list has the correct contents based on messages in other threads on this topic, I still get the warning message that those threads say to ignore and when I run apt-get upgrade, nothing is seen to be upgraded despite the message in a browser connected to that server asking me to upgrade it.
contents of /etc/apt/sources/list.d/plexmediaserver.list:
results of “apt-get update”:
All packages are up to date.
W: Conflicting distribution: https://downloads.plex.tv/repo/deb public InRelease (expected public but got )
The results of executing “apt-get upgrade” are:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
a. the warning is a misnomer.
b. apply updates manually please while we get the new repos ready to go live.
c. this and likely the next few will be manual update (download manually) only.
that’s where I’m struggling as a paranoid newbie. How do I update manually? I know how to install from scratch, but I don’t understand how to download and apply an update manually. I’m sure this is a terribly basic question, but… I’m a terribly basic user. My ultimate fear is that I will wipe out all of the work I’ve done thus far with organizing my library of music, TV shows, DVR configuration. I’ve tried searching for a few hours to find this in the forums to avoid pestering and annoying folks, but I just can’t seem to locate instructions other than “use apt-get update / upgrade” and that apparently isn’t functional currently. :frowning:
Updating uses the same commands.
On Linux, the installer detects whether updating or installing fresh and works accordingly.
On Ubuntu/Debian: sudo dpkg -i packagefile.deb
On Centos/Redhat: sudo yum install packagefile.rpm
On Fedora: sudo dnf install packagefile.rpm
I figured it would be so simple that it’s embarrassing. And, yep, I’m embarrassed. Thank you very much for the guidance!
