Server Version#: Version 1.41.3.9314
Player Version#: Version 4.141.0
I just upgrade my plex server to version v.1.41.3.9314 and now getting issues. I’ve been upgrading just fine for the past few years. I usually try not to mess with things that are working just fine. But it was listed as a “STABLE” version. Not sure what is going on. It started with my Live TV/DVR. It lost all of the channels and told me to delete the DVR and re-add. did that and now can’t get a channel lineup. It can’t find anything when I put in the Zip code. Also it will only work if I connect locally to the local ip without HTTPS. Using HTTPS gives me a ton of issues. I get the following log issues.
Chuck you have been a lifesaver here for too many years.
Thanks! I looked into my resolv.conf and saw that that my nameserver was set to 127.0.0.53 and then looked at resloved.conf and there weren’t any dns servers listed.
I modified the resolv.conf to an actual dns server and it’s working now.
This is something that I have never really messed with on the server (since it is only for plex). Things just always seemed to work. Not sure why just after this upgrade it made its presence know.
