Even though I have the toggle for Plex Pass Downloads set to Yes, I still only have version 1.8.1.4139 available. Likewise, the server is set to use the Plex Pass channel for automatic downloads. Am I missing something?
Thanks,
Andrew!
There is no version 2.0 of the Media Server, yet.
Newbie Q!
Hi trumpy81, what’s the difference between v2.1.0.74 - web download - you refer to and the regular - in app - update I’m offered v1.8.1.4139? Why are there 2 versions of the same app, I’m confused.
The update to 2.1 of PMP is only offered within the app, if your ‘Update Channel’ is set to ‘Plex Pass’.
@OttoKerner said:
@8mmToDigital said:
Hi trumpy81, what’s the difference between v2.1.0.74 - web download - you refer to and the regular - in app - update I’m offered v1.8.1.4139? Why are there 2 versions of the same app, I’m confused.The update to 2.1 of PMP is only offered within the app, if your ‘Update Channel’ is set to ‘Plex Pass’.
You can download it manually front the website as well. I had to as it wouldn’t auto update, even when following the guidance they provided.
Thank you everyone for taking the time to help me out here, appreciated! Cheers
