Server Version#: 1.19.4.2935
Player Version#: 1.12.1.1253-c29aa096
Hi everyone,
I was using my provider router before without any problem and changed to a Nighthawk R6700 a month ago.
At the same time I upgraded Plex MS and remote access didn’t work automatically using UPnP.
I can see on the router that the port is properly opened but in the remote access settings of Plex it turns green and then after less than a second port changes to 0 and it doesn’t work anymore.
I’ve found a fix which is forcing the port in Plex and use the one that is displayed on my router interface.
But I’m experiencing power outages (from my provider) and every time my router restarts (my NAS which is hosting Plex doesn’t reboot as it’s just a super short cut) I have to set Plex with automatic port, then check my router to find the port and finally force the port.
It’s a bit boring and I would expect it to work perfectly as it was before.
Again I can’t tell if the problem comes from Plex or my router as I found posts at exactly the same time explaining that people lost Remote Access.
In my router I can set the number of hops in UPnP. It was set to 4 and I’ve changed to 12 but it doesn’t change anything.
Should I increase this setting?
Here are some logs when it doesn’t work:
Summary
Jun 11, 2020 18:50:39.928 [0x7f865fa23700] Debug — NAT: UPnP, found device http://192.168.1.1:5000/Public_UPNP_gatedesc.xml with private address <192.168.1.34>
Jun 11, 2020 18:50:41.930 [0x7f868d028700] Debug — NAT: UPnP, found device http://192.168.1.1:5000/Public_UPNP_gatedesc.xml with private address <192.168.1.34>
Jun 11, 2020 18:50:43.985 [0x7f865fa23700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANIPConnection:1).
Jun 11, 2020 18:50:46.039 [0x7f868d028700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANIPConnection:1).
Jun 11, 2020 18:50:48.094 [0x7f865fa23700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANPPPConnection:1).
Jun 11, 2020 18:50:48.094 [0x7f865fa23700] Debug — NAT: UPnP, didn’t find usable IGD.
Jun 11, 2020 18:50:48.344 [0x7f865fa23700] Debug — NAT: UPnP, attempting port mapping.
Jun 11, 2020 18:50:50.147 [0x7f868d028700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANPPPConnection:1).
Jun 11, 2020 18:50:50.147 [0x7f868d028700] Debug — NAT: UPnP, getPublicIP didn’t find usable IGD.
Jun 11, 2020 18:50:52.200 [0x7f865fa23700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANIPConnection:1).
Jun 11, 2020 18:50:54.253 [0x7f865fa23700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANPPPConnection:1).
Jun 11, 2020 18:50:56.256 [0x7f868d028700] Debug — NAT: UPnP, found device http://192.168.1.1:5000/Public_UPNP_gatedesc.xml with private address <192.168.1.34>
Jun 11, 2020 18:51:00.364 [0x7f868d028700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANIPConnection:1).
Jun 11, 2020 18:51:02.419 [0x7f865fa23700] Debug — NAT: UPnP, possibly usable device http://192.168.1.1:5000/Public_UPNP_gatedesc.xml with private address <192.168.1.34>.
Jun 11, 2020 18:51:04.473 [0x7f868d028700] Debug — NAT: UPnP, not connected or has no external IP: http://192.168.1.1:5000/Public_UPNP_gatedesc.xml(urn:schemas-upnp-org:service:WANPPPConnection:1).
Jun 11, 2020 18:51:04.473 [0x7f868d028700] Debug — NAT: UPnP, getPublicIP didn’t find usable IGD.
Jun 11, 2020 18:51:08.580 [0x7f865fa23700] Warning — NAT: UPnP, error mapping port 19335, error: Unknown Error, controlURL: http://192.168.1.1:5000/Public_UPNP_C3.
It’s funny cause when it works (port forced) I can’t find the port number in the logs…
It would be great if someone could help
Thanks in advance.
