I've running 0.5.1 on a PI B+ normally without issues.
Yesterday I had a "cold interrupt" (power failure) and after getting back power and booting of the PI, the USB IR remote is no longer working.
I already did serval reboots via ssh, but the USB IR won't come back again.
Oh, the remote and receiver are ok, working fine on a WIN laptop.
Any suggestions (like checking the driver or the module is up and running or so) ?
Thanks in advance.
The power failure may have corrupted your SD card, suggest reflashing, if you want to keep your existing settings copy the guisettings.xml in the Userdata folder to a local machine and then copy back when you have rebooted with the newly flashed image and Restart, you will have to run pre-cache again.
