Are you aware that you can, after creating the filter list above, multi-select the results (select the first item, shift-click the last) and apply a label to all of them at once? In this case ‘Kids’ could be set as the label.
It probably wouldn’t take any longer than doing a Save As → Smart Sharing Label. Plus, it already exists.
Just want to be sure we’re not reinventing the wheel.
The point is that the smart filter applies to newly added content automatically once the smart filter is saved - exactly how it works with smart collections and smart playlists
Just wondering… what you’re asking for is an option to customize the access restrictions, using the mechanisms of advanced filters.
Applying labels based on a smart filter seems like a technicality / extra layer of complexity.
I don’t know.
Just trying to clarify the feature you’re aiming for (avoiding to lock this to a particular technical implementation). Dynamically writing labels seems like a stepping stone towards a more granular configuration of sharing restrictions.
Your description seems to focus a lot on assigning labels.
I’m trying to understand if this is actually about those “automatically assigned labels” or if those are simply a means to accommodate the primary target of a more flexible option to customize library access.
The reason I’m asking this is because the step of creating auto-labels which you could then use to restrict access seems like a workaround (unless you want to use those labels elsewhere).
Kometa does a lot of what your are asking, and I use it to place permission labels as well as others (not sure if it can look at folders, but it might):
For example, I have a Hallmark Channel Collection. The first part of script looks up a TMDB list (a Hallmark Channel movie list) and the script then assigns “Hallmark Channel” to the genre tag of all the matching movies on my Plex server. The second part of script then creates the smart collection based on that “genre” data and some other “studio” data.
I could easily add this to the script to add a label to all the movies too to set a label for all the matching movies called “Age 14” (you can call it “Kids” or whatever you wish, I just personally like to assign an Age label in the range of: Age 0,3,5,8,10,12,14,16,18,22,25 to all my content so I can change restrictions of a specific user without changing my mind about the appropriateness of a specific title as my kids grow up.):
