Use the media keys from the remote on an Android TV Box
On an Android TV Box, used via a remote, I’d like to be able to use the media keys (play / pause at least) and not have to go through the menu.
What Android TV device has media keys?
any Android box TV with a remote and more especially if you control it via a Logitech Harmony device.
Those media keys works perfectly with the other apps but not with Plex. Seems to be a mapping issue
Android TV is an operating system is it not a device. many devices claiming to be “Android TV” run regular or customized Android mobile in landscape and have an HDMI port. This for example does not run Android TV OS https://www.amazon.com/GooBang-Doo-Android-Marshmallow-Amlogic/dp/B01MZ8QCED/
Actual Android TV devices of which there are few ( like the Nvidia shield ) usually have only directional, home and back buttons. this is why i am curious what devices that run Android TV OS have them because i have never seen one ( not trying to say idea is bad )
That’s why I discussed about Android TV Boxes since my first post in this topic.
Now since you want links from Amazon:
https://www.amazon.com/XBMCMart-Android-Media-Player-64-Bit/dp/B06WP29NHV/ref=sr_1_8?s=electronics&ie=UTF8&qid=1498021525&sr=1-8&keywords=android+tv+box+%2B+remote (not the one I have but does not matter)
The media keys are natively managed by the system. You can even buy a remote with an IR USB dongle, plug it and use or
Or use a Logitech Harmony if your box has IR. It will just work out of the box, without setup.
By working, I mean, I can use those with Kodi, Molotov, Spotify, …
