Server Version#: 1.18.1.1973
Player Version#: All
Updating Plex Media Server on Linux PCs and Raspberry Pis results in the need to edit various files and ownership. So it goes as follows
Edit file /lib/systemd/system/plexmediaserver.service to change user=XXXX and group=XXXX # and replace XXXX with pi
sudo chown -R pi:pi /var/lib/plexmediaserver
sudo systemctl stop plexmediaserver
sudo systemctl daemon-reload
Should I add plex as a user and group and to the sudoers list?
Respectfully,
NO, Do not modify /lib/systemd/system/plexmediaserver.service
When updates are installed, anything in /lib is overwritten by the package manager.
I have set the flag to guarantee this.
To customize your PMS installation, which will persist from update to update,
Please use the systemd documented and supported method
https://forums.plex.tv/t/customizing-your-plex-configuration/205443
As supplemental information,
Plex Media Server is intended to run as a non-privileged user.
At no time does it require or can it even invoke root privilege.
system
Closed
February 2, 2020, 7:23pm
4
