Server Version#: 4.34.4
I used to be able to attach 2 servers to my Plex Account with no problems switching between the two. I’m sure there are more users like me that might have this issue. We this be resolved?
Many people are using multiple Plex servers successfully today. Can you describe what you’re attempting to do, and what’s happening for you?
I have 2 Qnap Servers with Multimedia Folders. I actually set this up last night and when I refreshed the app on my 2018 Model Samsung Qled TV, it will only let me choose 1 server to use.
you might need to access it via ssh tunnel for initial set up. https://support.plex.tv/articles/200288586-installation/#toc-2
I will try this for server 2 , and get back to you. Thanks for the detailed solution
Assuming the Samsung app works like the other apps …
Once you have both servers up and working, you should be able to “Pin” libraries from both servers, so that they both appear in the sidebar navigation at the same time.
But I confess I’m a bit confused. Are you having trouble setting up the second Qnap server, or are you having trouble browsing and viewing them from your TV?
It was the app not allowing me to choose but one server. I now have it fixed. I restarted the TV and now it is showing both servers on side bar.
Thanks to all !!!
