Using Plex Server with Google WiFi - Double NAT
Ever since switching to Google WiFi (which I love as I now have great internet service all throughout my house) I am unable to access my PLEX server. I keep getting this under the server settings on PLEX
Not available outside your network
Your server is signed in to Plex, but is not reachable from outside your network. Learn more
Tip: It looks like your server may be connected to the internet through multiple routers or other network devices. Try connecting it directly to your primary device, or visit our support site for more information about troubleshooting this “Double-NAT” scenario. Learn more
I clicked on the links… so Google WiFi can’t bridge if you’re using it in mesh, which basically means you’re using the three wfi spots instead of one, which I am.
I’m using a Netgear C6300BD through **** Cable, so the coaxial from cable is plugged in to that, and then I have an ethernet plugged in to the main Google WiFi router which the other two in the house are connected to. Trying to watch my Plex server through Firestick and Apple TV i the house (all connected to the same network - Google Wifi) and through laptop and phone/tablets outside the house when I travel. This used to be no issue but now I can’t access the server at all.
Anyone else having issues or been able to crack the Google Wifi nut?
Thank you!!!
I am having the exact same issue. I tried to port forward as described in plex support but I had no luck and frankly I was getting outside of my tech comfort zone. Any help would be much appreciated.
I do not have Google Wifi to test with unfortunately. Have you forwarded your ports in your router firewall and software firewall?
Google Wifi Port Forward:
https://support.google.com/wifi/answer/6274503?hl=en
Netgear C6300BD Port Forward:
http://screenshots.portforward.com/routers/Netgear/C6300BD/Port_Forwarding.htm
