Using PS3 Controller as Plex Remote
Was looking for a remote for my Linux Plex Client. If you're interested in setting this up, here you go!
I'm using a Ubuntu variant, Lubuntu. Your mileage may vary...
When you run sixad, be sure to note the Controller ID: Connected 'PLAYSTATION(R)3 Controller (04:98:F3:F0:FB:40)'
Install and configure QtSixA (youtube): http://www.youtube.com/watch?v=C2yKiMxisM0
You may want to start sixad at boot:
sudo sixad start boot-yes
Profiles define keymaps and controller options. They are read every time the controller is connected and are stored here:
 /var/lib/sixad/profiles/[Controller ID]
and stores as a file name matching the Controller ID like xx:xx:xx:xx:xx
Now we need create a profile (I stole the one I'm using from here.) Now open your terminal and type:
sudo nano /var/lib/sixad/profiles/xx:xx:xx:xx:xx
(make sure to replace xx:xx:xx:xx:xx with your Controller ID)
Then copy the text below and paste it into nano (via right-click > Paste).
# Input - "PLEX", by "wellspokenman"
# taken from http://forum.xbmc.org/showthread.php?tid=137085
Features (input is what lets you use keyboard presses, joystick for axis/js recognition)
enable_leds 1
enable_joystick 1
enable_input 1
enable_rumble 0
enable_timeout 1
LED
led_n_auto 1
led_n_number 1
led_anim 1
Joystick (notice that only the joystick axis is enabled - then prevents double keying for apps that recognise the js automatically)
enable_buttons 0
enable_sbuttons 0
enable_axis 1
enable_accel 0
enable_accon 0
enable_speed 0
enable_pos 0
Input - “XBMC-Keyboard”, by “Wellspokenman”
O - CPU Usage
key_select 24
Q - Queue
key_l2 16
W - Stop
key_r2 17
TAB - Fullscreen
key_start 15
UP
key_up 103
RIGHT
key_right 106
DOWN
key_down 108
LEFT
key_left 105
F4 - Load state (zsnes, mednafen, mupen64)
key_l3 62
F2 - Save state (zsnes, mednafen, mupen64)
key_r3 60
Pageup
key_l1 104
Pagedown
key_r1 109
C - Context Menu
key_tri 46
Backspace - back
key_cir 14
I - Info
key_squ 23
Enter - Select
key_cro 28
Esc - Previous menu
key_ps 1
axis_left_type 0
axis_left_up 0
axis_left_right 0
axis_left_down 0
axis_left_left 0
axis_right_type 0
axis_right_up 0
axis_right_right 0
axis_right_down 0
axis_right_left 0
axis_speed 6
use_lr3 0
Rumble
old_rumble_mode 0
Timeout
timeout_mins 5
Now save and connect your controller, via PS3 button. Open up your Plex client and check it out.
Enjoy.
Awesome, thanks.  I actually used my PS3 controller on XBMC and the respose is lightning fast.
