In line with Multiple country setup
DVB-S2 Setup with 2 Tuners is working fine. But now I want to use multiple Guides (not only one for my Country/ZIP region) for both Tuners. What is the best way to do so?
Might give xteve a try. Not sure if it will detect your tuners, if not you could create a m3u8 dummy list of your channels. Just make sure that Plex uses the tuners directly so xteve does not transcode them and only use xteve to import the xmltv guide data. You will need to grab xmltv guide data for the regions you want if you can and then map them to your channels in xteve.
There are other options but in a nutshell you will probably need to get your guide data for the various regions in xmltv format and then combine them in to one xmltv file to import in to Plex.
